Введение
The Random Access Memory (RAM) stores information that needs to be retrieved quickly or often. The RAM is one common component in a laptop that fails often and needs to be replaced. Use this guide to replace broken the RAM on your Acer Aspire V3-551-8469 laptop. No complicated manipulation is required.
Выберете то, что вам нужно
To release the battery, slide the orange tab to the right with a spudger.
The battery is now released and can be picked up and set to the side.
Use two plastic opening tools to pry the two clips outward to release the RAM chip.
