Введение
Removing the back panel gives access to most everything else in the laptop.
Запчасти
Никакие детали не требуются.
  1. Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Use a spudger to pry the panel up from the laptop case and remove it. The laptop should now be open with the RAM and wifi chip now accessible.
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
Заключение
Jacob Lesinski
Участник с: 22.04.2014
143 Репутация
1 Guide authored
Команда
Cal Poly, Team 8-8, Regan Spring 2014 Member of Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 членов
Автор 7 руководств
Один комментарий
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 9
За всё время: 1,429
