Введение
USB is essential on modern laptops. Use this guide to fix your broken ports.
Выберете то, что вам нужно
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Use a spudger to pry the panel up from the laptop case and remove it.
The laptop should now be open with the RAM and wifi chip now accessible.
Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
Carefully remove the wifi chip.
Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
Remove the panel and flip it up onto the keyboard
With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
Carefully disconnect the ribbon cable.
7 участников успешно повторили данное руководство.
