Acer Aspire V5-122P-0889 CPU fan Replacement
Выберете то, что вам нужно
  1. Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: шаг 1, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: шаг 1, изображение 2 из 2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 2, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 2, изображение 2 из 2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 3, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 3, изображение 2 из 2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 4, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 4, изображение 2 из 2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 5, изображение 1 из 1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 6, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 6, изображение 2 из 2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: шаг 7, изображение 1 из 2 Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: шаг 7, изображение 2 из 2
    • Remove the three screws that hold the fan into place.
    • Two of the screws remain attached to the metal heat-sink part of the fan after being unscrewed. This is normal, as they are build into the heat-sink.
  8. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 8, изображение 1 из 1
    • Disconnect the power cable that connects the fan to the motherboard.
  9. Acer Aspire V5-122P-0889 CPU fan Replacement: шаг 9, изображение 1 из 1
    • Remove the CPU fan from the laptop.
Заключение
Еще один человек закончил это руководство.
Katelynn couto
Участник с: 03/07/16
693 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 5-1, Landers Spring 2016 Участник UMass Dartmouth, Team 5-1, Landers Spring 2016
UMASSD-LANDERS-S16S5G1
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 1,374
