Acer Aspire V5-122P-0889 Network Card Replacement
Выберете то, что вам нужно
  1. Acer Aspire V5-122P-0889 Network Card Replacement, Battery: шаг 1, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement, Battery: шаг 1, изображение 2 из 2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 2, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 2, изображение 2 из 2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 3, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 3, изображение 2 из 2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 4, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 4, изображение 2 из 2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 5, изображение 1 из 1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 6, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 6, изображение 2 из 2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 Network Card Replacement, Network Card: шаг 7, изображение 1 из 2 Acer Aspire V5-122P-0889 Network Card Replacement, Network Card: шаг 7, изображение 2 из 2
    • Start by removing the antenna cable attached to the network card.
  8. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 8, изображение 1 из 1
    • Unscrew the two 3mm screws holding the network card in place.
  9. Acer Aspire V5-122P-0889 Network Card Replacement: шаг 9, изображение 1 из 3 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 9, изображение 2 из 3 Acer Aspire V5-122P-0889 Network Card Replacement: шаг 9, изображение 3 из 3
    • Carefully remove the network card by pulling it backwards, out of the slot that it is plugged into.
Заключение
2 участников успешно повторили данное руководство.
Katelynn couto
Участник с: 03/07/16
693 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 5-1, Landers Spring 2016 Участник UMass Dartmouth, Team 5-1, Landers Spring 2016
UMASSD-LANDERS-S16S5G1
3 членов
Автор 10 руководств
2 Комментариев
Why you should quite battery to take out the wifi card?
Regards
Vibra - Ответить
Agreed, no need to pull battery to pull the wifi card, make sure you are ground and you are good to pull and replace.
Cyrus Fox - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,005
