Acer Aspire V5-122P-0889 Touch pad Replacement
Выберете то, что вам нужно
  1. Acer Aspire V5-122P-0889 Touch pad Replacement, Battery: шаг 1, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement, Battery: шаг 1, изображение 2 из 2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 2, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 2, изображение 2 из 2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 3, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 3, изображение 2 из 2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 4, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 4, изображение 2 из 2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 5, изображение 1 из 1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 6, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 6, изображение 2 из 2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 Touch pad Replacement, Touch pad: шаг 7, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement, Touch pad: шаг 7, изображение 2 из 2
    • Start by carefully removing the ribbon cable that is plugged into the touch pad.
    • To remove it, gently pull the ribbon cable away from the slot that it is seated in.
  8. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 8, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 8, изображение 2 из 2
    • Remove the three visible screws below the touch pad that hold the bracket in place.
  9. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 9, изображение 1 из 1
    • Lift and remove the metal bracket from below the touch pad.
  10. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 10, изображение 1 из 2 Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 10, изображение 2 из 2
    • Lift and remove the foam-like piece that is located above the touch pad. Note that it is secured by adhesives, and can be reattached after replacing the touch pad.
    • Remove the last four screws that hold the touch pad in place.
  11. Acer Aspire V5-122P-0889 Touch pad Replacement: шаг 11, изображение 1 из 1
    • Finally, remove the touch pad from the laptop.
Заключение
Еще один человек закончил это руководство.
Katelynn couto
Участник с: 03/07/16
693 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 5-1, Landers Spring 2016 Участник UMass Dartmouth, Team 5-1, Landers Spring 2016
UMASSD-LANDERS-S16S5G1
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 968
