Введение
This guide provides in-depth instructions on how to remove the cover on the Acer Aspire V5-131-2629
Does your computer have a cracked or broken back plate? Do you need to get inside of your computer to replace internal components? This guide details the steps needed to remove the back cover on the Acer Aspire V5 laptop. To reassemble the back cover, just retrace the steps taken to remove the back cover.
Unfortunately, the Acer website has taken down information regarding this device. However, a basic, rather informal summary of the details and specs can be found at the following link:
++Acer Aspire V5-131-2629 prices and specs++
A general disassembly tutorial of the device can be found:
++How to Disassemble the Acer Aspire V5 131++
Выберете то, что вам нужно
Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
Remove the single Phillips #0 screw from the cover on the underside of the laptop.
Еще один человек закончил это руководство.
