Введение
Key replacement is necessary if some of the keys get stuck or aren't working due to the external hardware. Keyboard malfunction may also occur if drivers are outdated, and this issue can be resolved by following these troubleshooting instructions. If you have ruled out this issue, proceed with the key replacement. Be sure to power off and unplug the device before replacing any parts.
Выберете то, что вам нужно
Place the end of a plastic opening tool underneath the edge of the broken key.
Gently pry up on the key until it comes loose.
