Acer Aspire V5-571 Cooling System Replacement
Выберете то, что вам нужно
Видео обзор
  1. Acer Aspire V5-571 Cooling System Replacement, Keyboard: шаг 1, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement, Keyboard: шаг 1, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement, Keyboard: шаг 1, изображение 3 из 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
    ENT - Ответить
  2. Acer Aspire V5-571 Cooling System Replacement: шаг 2, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 2, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 2, изображение 3 из 3
    It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
    ENT - Ответить
    I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
    ENT - Ответить
  3. Acer Aspire V5-571 Cooling System Replacement, Optical Drive: шаг 3, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: шаг 3, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: шаг 3, изображение 3 из 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: шаг 4, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: шаг 4, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: шаг 4, изображение 3 из 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
    After removing the 18x Phillips screws, the laptop is VERY fragile in the hinge area. The bottom cover will easily crack or break in the hinge area when opening the laptop with no screws, particularly the left side near the power button. Possibly this step should be revised to recommend opening the laptop 90 degrees before removing the 18x screws. Or, advise extreme caution when opening the laptop with no screws.
    jonnyquest - Ответить
    Hi, do you know where buy screws that you mention in step 4? “Remove 18x Phillips screws from the bottom cover.”
    I am italian. Thank you anyway.
    Sara Caruso - Ответить
    The laptop I have included 6x screws from inside and 16x screws from the bottom. This seems to be a minor variation from model to model.
    William Fulton - Ответить
    Same with my model @sara Caruso. The six of them, and the two to release the keyboard, are shorter than the 18. All the screws had blue locktite on them.
    ENT - Ответить
  5. Acer Aspire V5-571 Cooling System Replacement: шаг 5, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 5, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 5, изображение 3 из 3
    • Carefully separate the upper cover and remove it.
    In my unit, there was also a screw holding the DVD drive in place, just toward the center from the drive itself. This screw also had to be removed to be able to remove the upper cover
    Ken Hill - Ответить
  6. Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): шаг 6, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): шаг 6, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): шаг 6, изображение 3 из 3
  7. Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: шаг 7, изображение 1 из 2 Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: шаг 7, изображение 2 из 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Cooling System Replacement, Mother Board: шаг 8, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement, Mother Board: шаг 8, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement, Mother Board: шаг 8, изображение 3 из 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Cooling System Replacement: шаг 9, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 9, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 9, изображение 3 из 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Cooling System Replacement: шаг 10, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 10, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 10, изображение 3 из 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: шаг 11, изображение 1 из 2 Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: шаг 11, изображение 2 из 2
    • Disconnect the Fan cable.
    • Unscrew the screws that hold the Cooling system to the Mother board.
    • Carefully lift the Cooling system right up.
  12. Acer Aspire V5-571 Cooling System Replacement: шаг 12, изображение 1 из 2 Acer Aspire V5-571 Cooling System Replacement: шаг 12, изображение 2 из 2
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
    • Remove three Philips screws held the Fan shield.
  13. Acer Aspire V5-571 Cooling System Replacement: шаг 13, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 13, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 13, изображение 3 из 3
    • Unstick the black tape that hold the Fan to the cooler.
    • Unlock the clip and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler
    • Close the Fan system.
  14. Acer Aspire V5-571 Cooling System Replacement: шаг 14, изображение 1 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 14, изображение 2 из 3 Acer Aspire V5-571 Cooling System Replacement: шаг 14, изображение 3 из 3
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
    • Did you do it successful?
Заключение
4 участников успешно повторили данное руководство.
ZFix
Участник с: 12/09/13
191 278 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 528 руководств
Один комментарий
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
lukasrohrer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 45
За всё время: 9,136
