Acer Aspire V5-571 Optical Drive Replacement
Выберете то, что вам нужно
Видео обзор
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: шаг 1, изображение 1 из 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: шаг 1, изображение 2 из 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: шаг 1, изображение 3 из 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
    ENT - Ответить
  2. Acer Aspire V5-571 Optical Drive Replacement: шаг 2, изображение 1 из 3 Acer Aspire V5-571 Optical Drive Replacement: шаг 2, изображение 2 из 3 Acer Aspire V5-571 Optical Drive Replacement: шаг 2, изображение 3 из 3
    It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
    ENT - Ответить
    I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
    ENT - Ответить
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: шаг 3, изображение 1 из 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: шаг 3, изображение 2 из 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: шаг 3, изображение 3 из 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Заключение
4 участников успешно повторили данное руководство.
ZFix
Участник с: 12/09/13
191 182 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 521 руководств
2 Комментариев
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Ответить
Is it safe to use the laptop with the optical drive out?
Vianca - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 5,115
