Введение
Follow this guide to replace the charging port on a Acer Aspire V5-571P-6815 laptop.
Выберете то, что вам нужно
Slide the locking latch to the right and hold while pulling the battery out with your other hand.
Insert a plastic opening tool underneath the keyboard and pry upwards.
Slide the plastic opening tool around the perimeter to free the keyboard.
Flip the keyboard over and onto the palm rest.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Remove the keyboard from the laptop.
Remove the six 6mm Phillips #0 screws from underneath the keyboard.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
Pull the ribbon cable from the socket.
Use a plastic opening tool to pry up the palm rest from the laptop body.
Remove the palm rest from the laptop.
Follow the steps in reverse with a new cable.
Еще один человек закончил это руководство.
