Введение
A guide on how to replace the touchscreen on a Acer Aspire V5-571P-6815 laptop.
Выберете то, что вам нужно
Slide the locking latch to the right and hold while pulling the battery out with your other hand.
Insert a plastic opening tool between the screen and lid.
Work the plastic opening tool around the perimeter while prying upwards until the screen separates from the lid.
Remove the camera using a pair of blunt nose tweezers.
Peel up the adhesive tape keeping the camera's cable tied down.
Remove the microphone from the motherboard with a pair of blunt nose tweezers.
Slide out the adhesive tape securing the microphone cable.
Lift up the ribbon cable contained by the adhesive strip with blunt nose tweezers.
Use a spudger to flip up the retaining flap on the digitizer ribbon cable ZIF socket.
Pull the ribbon cables out of their sockets.
Use the blunt nose tweezers to peel up the adhesive on the display cable.
Pull on the adhesive tape to disconnect the display from the motherboard.
Lift the whole strip connected to the circuit board and LCD connector. Place the strip to the side where it is not in contact with the screen.
Remove the whole screen from the device.
Еще один человек закончил это руководство.
Один комментарий
The heading of your Procedure is “Acer Aspire V5-571P-6815 Touchscreen Replacement” BUT you just opened up the entire screen.
NOTE: you didn’t separate the “TOUCH SCREEN” from the LCD screen.
This supposed to be the most important part of your procedure item ! ! ! !
PLEASE……. ******
