Введение
If your laptop overheats, you must open it, clean the cooling system and replace the CPU thermal paste.
Выберете то, что вам нужно
Видео обзор
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Use a lint-free cloth to clean the old thermal compound.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
Remove the 3x Phillips screws and open the Fan case.
Use a soft brush and clean the Fan and the Cooler.
Use the same technic to clean the surface of the processor from the old thermal compound
Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
