Введение
How to disassemble Acer Aspire - V5-572, V5-572G and remove the Main board.
Выберете то, что вам нужно
Видео обзор
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Disconnect the SATA Cable from the Mother Board.
Take out the HDD and remove the SATA cable from it.
Now you can change / upgrade your HDD.
Remove 1x screw and disconnect the two antenna coaxial cables.
Remove the Wi-Fi card from the slot.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Disconnect one by one:
LCD Display flex cable
DC Jack cable
USB Board flex cable
Touch pad flex cable
Keyboard flex cable
Disconnect the Loudspeakers and the Microphone cables.
Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
Open a little the laptop to open the hinge.
By hand, open the hinge to the end.
Еще один человек закончил это руководство.
