Введение
This guide will show the user how to remove the fan and heat-sink.
Do not proceed with this guide unless you are prepared to clean and re-apply thermal compound. For more information, please refer to the How to Clean and Apply Thermal Compound guide.
Выберете то, что вам нужно
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
With the screws removed, flip the device right-side up and open up the display.
Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
Use a pair of blunt tweezers to gently push on the 3-pin connector. This disconnects the fan from the motherboard.
Use a Phillips #1 screwdriver to remove 6 black 10mm Phillips Head screws that connect the copper heat-sink to the motherboard.
Using both hands, gently lift the heat-sink and fan components from the motherboard.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
Еще один человек закончил это руководство.
