Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
Выберете то, что вам нужно
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: шаг 1, изображение 1 из 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: шаг 1, изображение 2 из 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: шаг 1, изображение 3 из 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 2, изображение 1 из 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 2, изображение 2 из 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 2, изображение 3 из 3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 3, изображение 1 из 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 3, изображение 2 из 2
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 4, изображение 1 из 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 4, изображение 2 из 2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: шаг 5, изображение 1 из 1
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
Заключение
Еще один человек закончил это руководство.
Ryan M
Участник с: 01/30/20
213 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 607
