Введение
This guide will walk you through replacing the screen of your Acer Chromebook 15 CB5-571-C09S.
Выберете то, что вам нужно
Wedge one of the plastic opening tool in the inside of the screen cover and run it along the inside perimeter of the screen.
Wedge the plastic opening tool inside the back of the screen cover and run along the perimeter of the screen.
Remove the screen cover from the screen.
Pry off a pair of small covers at the back of the hinges first.
Carefully grab the edges of the screen cover from opposite ends and pull off the screen towards you.
Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
Take out screen from top part of the device and lay it down flat on the key board.
Remove the screen connector from the back of the screen.
Peel and remove the sticker connecting the screen connector to the screen.
5 участников успешно повторили данное руководство.
