Acer Chromebook C710-2847 Back Cover Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: шаг 1, изображение 2 из 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: шаг 2, изображение 1 из 2 Acer Chromebook C710-2847 Back Cover Replacement: шаг 2, изображение 2 из 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: шаг 3, изображение 1 из 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
    Bradley,
    If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
    It's something I do with an old dell I use for checking out distros.
    Regards,
    Jack
    jack martin - Ответить
    I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
    You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
    cdac1234 -
    Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
    rwells78 -
    What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
    Jennifer Munoz - Ответить
    Mine is a Seagate ST320L T020
    Marshall Gates -
    do not so what the second picture shows and leave the battery in!
    brayton1234567 - Ответить
  4. Acer Chromebook C710-2847 Back Cover Replacement: шаг 4, изображение 1 из 2 Acer Chromebook C710-2847 Back Cover Replacement: шаг 4, изображение 2 из 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Заключение
9 участников успешно повторили данное руководство.
Bradley Pavy
Участник с: 09/30/13
1 257 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 13-3, Forte Fall 2013 Участник Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 членов
Автор 14 руководств
Один комментарий
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 6,286
