Введение
As a computer is used, it generates heat. The cooling fan pulls air through the device to cool it down. If it becomes clogged with dust or breaks, the computer will overheat.
Запчасти
No parts specified.
  1. Place the laptop on a flat surface with the bottom side facing up. Place the tip of a spudger or finger into the hole on the battery release slider.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Use the spudger to move the slider to the right and hold it there. With the slider held, use your other hand to pull the battery back away from the laptop.
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. This step will void your device warranty.
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Slide the back panel towards you. The best spots to place your fingers are on the bumpers. Lift on the front edge to remove the panel.
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. The hard drive assembly is attached to the laptop by a ribbon cable. Only lift the side of the drive facing you about an inch above the laptop. If you tear the ribbon cable the laptop will need to be serviced by a professional. Use one finger to lift up the hard drive assembly from the bottom left corner.
    • The hard drive assembly is attached to the laptop by a ribbon cable. Only lift the side of the drive facing you about an inch above the laptop. If you tear the ribbon cable the laptop will need to be serviced by a professional.
    • Use one finger to lift up the hard drive assembly from the bottom left corner.
  6. Hold the hard drive assembly keeping the end closest to you near the laptop. It's ok to tilt the far end of the drive up towards you. Unscrew the two silver #0 3mm Phillips screws on the left and right sides of the hard drive.
    • Hold the hard drive assembly keeping the end closest to you near the laptop. It's ok to tilt the far end of the drive up towards you.
    • Unscrew the two silver #0 3mm Phillips screws on the left and right sides of the hard drive.
  7. Hold the base of the hard drive in your right hand. Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable. Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable.
    • Hold the base of the hard drive in your right hand.
    • Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable.
  8. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  9. Pull the metal tabs sideways away from the memory stick. The RAM stick will pop up.
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  10. Pull the RAM stick up and away from the laptop. Pull the RAM stick up and away from the laptop.
    • Pull the RAM stick up and away from the laptop.
  11. Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card. Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card. Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  12. Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  13. The wireless card will spring up. Pull the wireless card up and out to remove it.
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
  14. Remove the SD card or placeholder by pressing the card in until it clicks and pops out. Pull the card out.
    • Remove the SD card or placeholder by pressing the card in until it clicks and pops out.
    • Pull the card out.
    • Remove the screws.
    • Sixteen #0 6mm Phillips screws
    • One #0 3mm screw
  15. Unplug the fan power cable by pulling the cable towards you using a spudger to help pop off the connection. Unplug the fan power cable by pulling the cable towards you using a spudger to help pop off the connection. Unplug the fan power cable by pulling the cable towards you using a spudger to help pop off the connection.
    • Unplug the fan power cable by pulling the cable towards you using a spudger to help pop off the connection.
  16. Unplug the cable below the lower RAM slot by using the spudger to slide the two brown clips towards you. Gently pull the cable towards you using the clear plastic tab. Gently pull the cable towards you using the clear plastic tab.
    • Unplug the cable below the lower RAM slot by using the spudger to slide the two brown clips towards you.
    • Gently pull the cable towards you using the clear plastic tab.
  17. Unclip the bottom half of the case from the laptop by using a spudger and starting at the USB port on the right side of the laptop. Then work your way clockwise around the laptop. Unclip the bottom half of the case from the laptop by using a spudger and starting at the USB port on the right side of the laptop. Then work your way clockwise around the laptop.
    • Unclip the bottom half of the case from the laptop by using a spudger and starting at the USB port on the right side of the laptop. Then work your way clockwise around the laptop.
  18. Open the laptop hinge about 45 degrees.
    • Open the laptop hinge about 45 degrees.
    • Lowering the keyboard assembly too far will damage the keyboard ribbon cable. Do not let the cable stretch.
    • Lower the keyboard assembly halfway between the case and the screen.
  19. Push down on the black tabs with a spudger to free the ribbon cable from the case. Gently pull the ribbon cable out of its slot. Gently pull the ribbon cable out of its slot.
    • Push down on the black tabs with a spudger to free the ribbon cable from the case.
    • Gently pull the ribbon cable out of its slot.
  20. Lower the keyboard assembly towards the screen until the clips near the hinges detach.
    • Lower the keyboard assembly towards the screen until the clips near the hinges detach.
    • Set the keyboard assembly aside.
  21. Open the hinge to about 90 degrees. Lift up the left edge of the tape holding the fan on the right side of the motherboard. Push the fan out of the back of the laptop.
    • Open the hinge to about 90 degrees.
    • Lift up the left edge of the tape holding the fan on the right side of the motherboard.
    • Push the fan out of the back of the laptop.
Заключение
6 участников успешно повторили данное руководство.
Bradley Pavy
Участник с: 30.09.2013
1 170 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 13-3, Forte Fall 2013 Member of Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 12
За всё время: 5,673
