Введение
The wireless card is responsible for connecting the Chromebook to Wi-Fi networks and Bluetooth devices.
Выберете то, что вам нужно
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the spudger to move the slider to the right and hold it there.
With the slider held, use your other hand to pull the battery back away from the laptop.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
Lift on the front edge to remove the panel.
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
The wireless card will spring up.
Pull the wireless card up and out to remove it.
2 участников успешно повторили данное руководство.
