Acer Chromebook C710-2847 Wireless Card Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: шаг 1, изображение 2 из 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: шаг 2, изображение 1 из 2 Acer Chromebook C710-2847 Wireless Card Replacement: шаг 2, изображение 2 из 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: шаг 3, изображение 1 из 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
    Bradley,
    If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
    It's something I do with an old dell I use for checking out distros.
    Regards,
    Jack
    jack martin - Ответить
    I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
    You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
    cdac1234 -
    Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
    rwells78 -
    What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
    Jennifer Munoz - Ответить
    Mine is a Seagate ST320L T020
    Marshall Gates -
    do not so what the second picture shows and leave the battery in!
    brayton1234567 - Ответить
  4. Acer Chromebook C710-2847 Wireless Card Replacement: шаг 4, изображение 1 из 2 Acer Chromebook C710-2847 Wireless Card Replacement: шаг 4, изображение 2 из 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: шаг 5, изображение 1 из 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: шаг 5, изображение 2 из 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: шаг 5, изображение 3 из 3
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: шаг 6, изображение 1 из 1
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: шаг 7, изображение 1 из 2 Acer Chromebook C710-2847 Wireless Card Replacement: шаг 7, изображение 2 из 2
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
Заключение
2 участников успешно повторили данное руководство.
Bradley Pavy
Участник с: 09/30/13
1 257 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 13-3, Forte Fall 2013 Участник Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 членов
Автор 14 руководств
Один комментарий
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 5,990
