Введение
In this replacement guide, you will learn how to safely remove and install a cooling fan.
Выберете то, что вам нужно
Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
Once completely unscrewed, carefully lift the cover off.
Place the cover and screw safely to the side for now.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Now take your anti-static wrist strap and place it tightly on your wrist.
Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
Locate the two 6 mm Phillips #00 screws on the fan port.
Unscrew the two screws and place them aside for now.
Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
Locate the Molex cable connecting the fan to its port in the top left corner.
Disconnect the cable.
Еще один человек закончил это руководство.
