Введение
In this replacement guide, you will safely remove and install a hard drive.
Выберете то, что вам нужно
Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
Once completely unscrewed, carefully lift the cover off.
Place the screw and cover safely to the side for now.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Now take your anti-static wrist strap and place it tightly on your wrist.
Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
Locate the hard drive.
Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
Take your driver with the PH00 bit attached and unscrew all four screws.
Place the screws off to the side for now.
Еще один человек закончил это руководство.
