Введение
The battery powers the laptop. Before taking anything out of the laptop, always remove the battery to avoid shocking yourself and damaging other components. Over time, the battery will lose the ability to charge. Replace the battery with a new one to regain your original battery life.
Выберете то, что вам нужно
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the spudger to move the slider to the right and hold it there.
With the slider held, use your other hand to pull the battery back away from the laptop.
16 участников успешно повторили данное руководство.
6 Комментариев
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
i have a C710-2815? what kind of battery do i need for a replacement
It is a sad state of things when being female makes you unsafe. On the other hand, you won't have the American Dream drafted away from you.
I ordered this battery before seeing this. Not only is voltage incorrect, but it does not latch.
https://www.amazon.com/gp/product/B00XDT...
Slides on, but connector mismatch and will not lock into place.
Sending back.
Also the BUY PARTS amazon button at the top right of this article is a 404 error.
