Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Acer Chromebook C710-2847 Battery Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C710-2847 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C710-2847 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Battery Replacement: шаг 2, изображение 1 из 2 Acer Chromebook C710-2847 Battery Replacement: шаг 2, изображение 2 из 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
Заключение
16 участников успешно повторили данное руководство.
Adam Whitmarsh
Участник с: 09/30/13
1 059 Репутация
1 руководство автора
Команда
Cal Poly, Team 13-3, Forte Fall 2013 Участник Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 членов
Автор 14 руководств
6 Комментариев
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
Daphne Macklin - Ответить
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
Tom Dison - Ответить
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
Cornell Gunter -
i have a C710-2815? what kind of battery do i need for a replacement
sudanna soetome - Ответить
It is a sad state of things when being female makes you unsafe. On the other hand, you won't have the American Dream drafted away from you.
xcoconino9 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 30,576
