Введение
Once your hard drive fails, it's pretty simple to replace! Just follow this guide to replace the hard drive in your device.
Выберете то, что вам нужно
Remove the one 4.3mm Phillips #1 screw holding the back cover on.
Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
Gently pull the drive up and away to disconnect the hard drive from its seat
Почти готово!
Заключение
