Acer Chromebook C720-2103 Battery Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C720-2103 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C720-2103 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Battery Replacement: шаг 2, изображение 1 из 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Battery Replacement: шаг 4, изображение 1 из 2 Acer Chromebook C720-2103 Battery Replacement: шаг 4, изображение 2 из 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Battery Replacement: шаг 5, изображение 1 из 2 Acer Chromebook C720-2103 Battery Replacement: шаг 5, изображение 2 из 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Заключение
Еще один человек закончил это руководство.
Matthew Holt
Участник с: 10/17/17
633 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Участник UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 784
