Acer Chromebook C720-2103 Fan Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C720-2103 Fan Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement, Battery: шаг 1, изображение 2 из 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Fan Replacement: шаг 2, изображение 1 из 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Fan Replacement: шаг 3, изображение 1 из 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Fan Replacement: шаг 4, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement: шаг 4, изображение 2 из 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Fan Replacement: шаг 5, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement: шаг 5, изображение 2 из 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Fan Replacement, Fan: шаг 6, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement, Fan: шаг 6, изображение 2 из 2
    • Remove all four 6mm screws attaching the fan to the motherboard with a Phillips #0 screwdriver.
    • Remove the two 6mm screws attaching the fan to the device base with the Phillips #0 screwdriver.
    • These screws are permanently set into the fan. Once unscrewed from the base, the two screws will still be attached to the fan.
  7. Acer Chromebook C720-2103 Fan Replacement: шаг 7, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement: шаг 7, изображение 2 из 2
    • Unsnap the two coaxial connectors from the motherboard.
    • To avoid damaging the wires, wedge a spudger under their rounded, metal ends and gently pop them up from the motherboard one at a time.
    • Unhook the coaxial wires from the side of the fan by gently pulling them downward and away from the hooks.
    • During reassembly, these two wires can be surprisingly difficult to reconnect to the motherboard. The easiest method is to hold the wires in place over their terminals and click the metal bases down with the tip of a spudger.
  8. Acer Chromebook C720-2103 Fan Replacement: шаг 8, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement: шаг 8, изображение 2 из 2
    • Peel up the tape attaching the rainbow connector wire to the motherboard, but leave the tape attached to the wire itself.
    • Removing the tape from the wire can damage the wire.
    • Pull the rainbow cable connector out of the black terminal by wiggling it gently from side to side with your fingers.
  9. Acer Chromebook C720-2103 Fan Replacement: шаг 9, изображение 1 из 2 Acer Chromebook C720-2103 Fan Replacement: шаг 9, изображение 2 из 2
    • Lift the fan component up and out of device with your hands. Take care not to knock the fan against the motherboard.
Заключение
Еще один человек закончил это руководство.
Matthew Holt
Участник с: 10/17/17
633 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Участник UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 521
