Acer Chromebook C720-2103 Solid State Drive Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: шаг 1, изображение 1 из 2 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 2, изображение 1 из 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 3, изображение 1 из 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 4, изображение 1 из 2 Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 4, изображение 2 из 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 5, изображение 1 из 2 Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 5, изображение 2 из 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: шаг 6, изображение 1 из 1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 7, изображение 1 из 3 Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 7, изображение 2 из 3 Acer Chromebook C720-2103 Solid State Drive Replacement: шаг 7, изображение 3 из 3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Matthew Holt
Участник с: 10/17/17
633 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Участник UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 273
