Введение
Simple and clear steps for replacing the cooling fan / CPU heat sink assembly on an Acer C720-2420 Chromebook.
Выберете то, что вам нужно
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
Remove the six 4.7 mm Phillips screws that secure the fan.
Disconnect these cables from the motherboard using the tweezers.
Pull out the fan.
