Введение
This guide will provide you with simple and clear steps on how to replace the motherboard on an Acer Chromebook C720-2420.
Выберете то, что вам нужно
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Remove the six 4.7 mm Phillips screws that secure the fan.
Lift up the black tab on the ZIF connector to release the ribbon cable.
Carefully remove the ribbon cable.
Gently remove the ribbon cable
Remove the ribbon cable.
