Введение
This guide explains how to remove the battery. Before removing the battery, the front panel assembly will also need to be removed. Once the battery is reached, you will need to unplug some cables and unscrew some screws.
Выберете то, что вам нужно
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
3 участников успешно повторили данное руководство.
