Введение
This guide will show you how to replace you Acer Chromebook C720-2827 LED PCB. The LED PCB is the printed control board controlling the two status LEDs (light emitting diode) on the bottom right edge of the laptop. Replace it if these two LEDs cease lighting up while the device is charging.
Выберете то, что вам нужно
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
Pull the ribbon cable out with your fingers.
