Введение
This guide will mainly focus on removing the speakers. First, you will need to remove the back panel. Next, you will need to remove the battery.
Выберете то, что вам нужно
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Почти готово!
Заключение
