Введение
Use this guide to replace the trackpad on your Acer Chromebook C720-2827. This guide may also be useful for cleaning or readjusting a trackpad that is semi-functional. It will require opening the device and removal of the battery. A plastic cover sits atop the trackpad joined by adhesive, so some light adhesive may be desired for reassembly.
Выберете то, что вам нужно
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
Peel off the clear plastic covering the screws.
Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
Еще один человек закончил это руководство.
