Введение
This guide instructs the reader how to disassemble, extract, replace, and reassemble the LCD monitor for an Acer Chomebook C720-2848.
Выберете то, что вам нужно
Insert a metal spudger around the inner side of the screens plastic perimeter.
Move along the perimeter while leveraging to pop the faceplate out like so.
Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
4 участников успешно повторили данное руководство.
Один комментарий
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
