Введение
If the motherboard for your Acer Chromebook (model C731-C8VE) is damaged, defective, or requires replacement for some other reason, this guide will help you to do so with ease.
Before removing the motherboard, you must remove cables that connect to peripheral components and the screws that hold the motherboard in place. Afterwards, removing the motherboard is as simple as lifting it out of place.
You will of course need to ensure that your laptop is completely powered off and not connected to a source of power to avoid risk of electrocution or other injury.
Выберете то, что вам нужно
Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
These 2 mm screws have washers and will be located on the left and right of the device.
The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
Remove the single 5 mm screw securing the wireless card in place using a JIS #00 screwdriver.
Carefully detach and remove the card.
Using a JIS #00 screwdriver, remove the four 1 mm screws that hold the motherboard in place.
Gently leverage the motherboard by using the spudger to nudge it from underneath.
Carefully grasp and remove the motherboard.
Еще один человек закончил это руководство.
