Введение
This is the trackpad replacement guide for the Acer Chromebook C731-C8VE. By following this guide, you should be able to completely remove the trackpad from your device. Make sure to follow all hazard warnings for your safety.
Выберете то, что вам нужно
Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
These 2 mm screws have washers and must be placed in these specific areas.
The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
