Выберете то, что вам нужно
Using a plastic opening tool or a spudger, carefully pry the plastic bezel around the screen.
Remove the four screws holding the display in place with a Phillips #1 screwdriver.
Carefully lower the display to rest on the keyboard.
The display connector is located on the back and is covered by some adhesive tape.
Carefully peal the tape back
Once the tape is peeled back, you can lift the bar to disconnect the display cable.
Еще один человек закончил это руководство.
