Введение
The LCD screen replacement for the Acer Chromebook C740 requires removing the screen frame, removing several screws, and unplugging the the LCD screen.
Выберете то, что вам нужно
With the Chromebook open and face up, pry the black screen frame with your fingers.
Move slowly around the display to evenly remove it.
Once the frame is separated from the display, angle the display assembly back .
Lift up the portions of the frame covering the front two hinges with the spudger.
Place the LCD screen face down on the keyboard.
Remove the tape holding the black connector in place.
Unplug the connector with your hands.
7 участников успешно повторили данное руководство.
Один комментарий
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
