Введение
This guide will demonstrate how to remove the motherboard from the Acer Chromebook C740-C4PE.
Выберете то, что вам нужно
Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
Use the spudger or any other prying tool to pry the back plate off of the device.
Remove the 5mm screw holding the SSD in place using the Phillips #0 screwdriver.
Remove the two 5mm screws holding the battery in place using a Phillips #0 screwdriver.
Remove the touchpad cable from the zero insertion force connector on the motherboard.
Remove the keyboard cable from the zero insertion force connector on the motherboard.
Remove the mother-to-daughter cable from the zero insertion force connector on the motherboard.
Remove the two 5mm screws holding the motherboard in place using a Phillips #0 screwdriver.
