Acer Chromebook C740-C4PE Motherboard Replacement
Выберете то, что вам нужно
  1. Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: шаг 1, изображение 1 из 3 Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: шаг 1, изображение 2 из 3 Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: шаг 1, изображение 3 из 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 2, изображение 1 из 2 Acer Chromebook C740-C4PE Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 3, изображение 1 из 2 Acer Chromebook C740-C4PE Motherboard Replacement: шаг 3, изображение 2 из 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 4, изображение 1 из 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 5, изображение 1 из 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 6, изображение 1 из 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 7, изображение 1 из 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
  8. Acer Chromebook C740-C4PE Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Remove the 5mm screw holding the SSD in place using the Phillips #0 screwdriver.
  9. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 9, изображение 1 из 2 Acer Chromebook C740-C4PE Motherboard Replacement: шаг 9, изображение 2 из 2
    • Slide the SSD out of its slot in the motherboard.
  10. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 10, изображение 1 из 1
    • Remove the two 5mm screws holding the battery in place using a Phillips #0 screwdriver.
  11. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 11, изображение 1 из 1
    • Remove the battery cable attached to the motherboard.
  12. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 12, изображение 1 из 1
    • Pull out the battery.
  13. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 13, изображение 1 из 2 Acer Chromebook C740-C4PE Motherboard Replacement: шаг 13, изображение 2 из 2
    • Remove the speaker cable from the motherboard.
  14. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 14, изображение 1 из 1
    • Remove the touchpad cable from the zero insertion force connector on the motherboard.
    • Be sure to push up the plastic tab that holds the cable in place before removing it. Failure to do this could result in snapping the cable.
  15. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 15, изображение 1 из 1
    • Remove the keyboard cable from the zero insertion force connector on the motherboard.
    • Be sure to push open the plastic tab that holds the cable in place before removing the cable.
  16. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 16, изображение 1 из 1
    • Remove the mother-to-daughter cable from the zero insertion force connector on the motherboard.
  17. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 17, изображение 1 из 1
    • Remove the LCD cable from the motherboard.
  18. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 18, изображение 1 из 1
    • Remove the two 5mm screws holding the motherboard in place using a Phillips #0 screwdriver.
  19. Acer Chromebook C740-C4PE Motherboard Replacement: шаг 19, изображение 1 из 1
    • Remove the motherboard.
    • Make sure your body does not have static electricity when handling the new motherboard as you could shock it. This could potentially break the new motherboard. Touch your finger on to something metal before handling the new motherboard.
Заключение
Dylan Tocci
Участник с: 10/17/17
237 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Участник UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 594
