Выберете то, что вам нужно
Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
Using the spudger or other prying tool, gently pry the back off of the device.
Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
Detach the connecting cable from the motherboard by pulling away.
Remove the battery from the device.
Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
Lift the silver restraint from the device.
Using a spudger, lift the black electrical tape to the left of the touchpad.
Remove the black wire running across the touchpad from the two hooks on top of the part.
