Введение
Use this guide to replace the battery in your Acer Chromebook CB3-111-C670.
If your Acer Chromebook CB3-111-C670 is experiencing power issues, taking longer to charge, or overheating, it may be time to replace its battery.
  1. Start by inspecting your charging cord. Wear and tear on your charging cord could mimic battery issues.
  2. Inspect the screen of your device for damage. A broken screen could prevent the display from turning on.
  3. Plug your charging cord into the device (and outlet). If the charging light does not come on, this may indicate a faulty battery.
This guide will walk you through each step to successfully replace the battery on your Acer Chromebook CB3-C670. Prior to starting this repair, make sure to back up any files, power off the device, and unplug from the power source.
Be sure to check the troubleshooting page prior to starting any repair.
  1. Be sure to have completely shut down the device before attempting to open it.
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Pull the battery connector cable towards the battery to disconnect it.
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Remove the battery.
    • Remove the battery.
Заключение
5 участников успешно повторили данное руководство.
Tony
Участник с: 20.01.2016
447 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 10-5, Remmell Spring 2016 Участник USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 членов
Автор 8 руководств
Один комментарий
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 57
За всё время: 3,517
