Acer Chromebook CB3-431-C5EX Battery Replacement
Выберете то, что вам нужно
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: шаг 1, изображение 1 из 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 3, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 3, изображение 2 из 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: шаг 4, изображение 1 из 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 5, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 5, изображение 2 из 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: шаг 6, изображение 1 из 1
    • Carefully lift the entire battery pack out of the laptop.
Заключение
7 участников успешно повторили данное руководство.
Elsa Bassett
Участник с: 04/18/17
414 Репутация
1 руководство автора
Команда
Cal Poly, Team S17-G3, Banghart Spring 2017 Участник Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 членов
Автор 10 руководств
2 Комментариев
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Ответить
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 17
За последние 30 дней: 68
За всё время: 8,610
