Acer Chromebook CB3-431-C5EX Motherboard Replacement
Выберете то, что вам нужно
  1. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Bottom Panel: шаг 1, изображение 1 из 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 3, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 3, изображение 2 из 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Battery: шаг 4, изображение 1 из 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 5, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 5, изображение 2 из 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 6, изображение 1 из 1
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: шаг 7, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: шаг 7, изображение 2 из 2
    • Remove the 4.7 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  8. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 8, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 8, изображение 2 из 2
    • Unplug the black wire connecting the small circuit board to the motherboard.
  9. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 9, изображение 1 из 3 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 9, изображение 2 из 3 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 9, изображение 3 из 3
    • Lift the respective white and black tabs and slide the ribbon cables out of their connectors.
  10. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 10, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 10, изображение 2 из 2
    • Carefully remove the display adapter from the motherboard.
  11. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 11, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 11, изображение 2 из 2
    • Remove the black tab connecting the motherboard to the keyboard.
  12. Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 12, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: шаг 12, изображение 2 из 2
    • Remove the five 4.7 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the two 4.5 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Gently remove motherboard from the laptop.
Заключение
Graham Caldwell Blondes
Участник с: 09/20/21
133 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 30
За всё время: 469
