Acer Chromebook CB3-431-C5EX Wireless Card Replacement
Выберете то, что вам нужно
  1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: шаг 1, изображение 1 из 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: шаг 2, изображение 1 из 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: шаг 3, изображение 1 из 2 Acer Chromebook CB3-431-C5EX Wireless Card Replacement: шаг 3, изображение 2 из 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: шаг 4, изображение 1 из 1
    • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
  5. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: шаг 5, изображение 1 из 1
    • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
  6. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: шаг 6, изображение 1 из 1
    • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
    • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
    • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
Заключение
3 участников успешно повторили данное руководство.
Holden Kurfess
Участник с: 04/18/17
358 Репутация
1 руководство автора
Команда
Cal Poly, Team S17-G3, Banghart Spring 2017 Участник Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,429
