Введение
Before beginning, make sure the Acer Chromebook CB5-132T-C8ZW is disconnected from any external power source; then press and hold the power button for at least five seconds prior to dismantling in order to release any stored energy that could potentially be harmful.
Выберете то, что вам нужно
Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
Remove the battery.
3 участников успешно повторили данное руководство.
