Выберете то, что вам нужно
First begin by flipping the laptop on its back and having the back cover face you directly.
Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
look for the battery in the bottom half of the computer
Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
Finally remove the battery from the laptop.
Remove the yellow tape covering the ribbon cable in the bottom left of the motherboard as shown.
Carefully remove the ribbon cable out from the connector.
Fold up the grey cover to release the ribbon cable in the bottom right of the board as shown.
Carefully pull out the ribbon cable from the port by the blue tape.
Fold up the white cover to release the ribbon cable in the top left of the board as shown.
Fold up the grey cover to release the cable on the top right of the board as shown
Carefully pull out the cable from the port.
Carefully pull off both brass connectors from the top left of the board with tweezers as shown.
Remove the six screws from the board as shown. There are two types of screws here, so be careful to keep them separate for reassembly.
2 участников успешно повторили данное руководство.
7 Комментариев
thanks for the write up! do you know where the bluetooth is on the motherboard? I presume step 10 are the connections to the wifi antennae?
This Chromebook likely uses a dual chip which can be seen in step 10. I’m guessing the chip is a 802.11AC 2x2 MIMO WLAN + Bluetooth 4.0 from looking at the specs.
wich is the firmware write protect screw on the motherboard to cheng the os to win10 ??
This is an ARM MT8173 machine, no Windows 10 for this hardware… Win10 for ARM is still on ARM based Surface, and gives poor experience.
Bonjour,
J ai un chromebook CB5-312T quelle carte mère je dois acheter et où mon chromebook ne s allume plus.
Merci
