Введение
Chromebooks traditionally have very small Solid State Drives (SSD) because most data is stored in the cloud. This particular model has a 32 GB SSD. However, if you have the need for a larger-capacity SSD, this guide will show you how to replace it.
Выберете то, что вам нужно
Remove the following eighteen screws using a Phillips #0 screwdriver.
Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
2 участников успешно повторили данное руководство.
